Kioti KL102 FEL won't lift after 30 minutes of operation
   / Kioti KL102 FEL won't lift after 30 minutes of operation #1
dlpritts
Central Pennsylvania
Kioti lb1914
I have recently encountered a problem with my FEL on my lb1914. After using it to move material for about 30 minutes it slowly loses lifting power until it will barely lift the empty bucket. Running up the RPMs on the tractor helps some but not for long. There have been no changes in the hydraulic system between the time the FEL was working fine and the start of this problem. The fluid level is OK, the filter is fresh, and no leaks around the controls, hoses, or cylinders.
Anyone know what could be causing this problem? Thanks in advance for any advice you may have.
   / Kioti KL102 FEL won't lift after 30 minutes of operation #2
check your pressures at the FEL.
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
