Oil & Fuel Kioti hydraulic & fuel guage problem
   / Kioti hydraulic & fuel guage problem #1
treesawer
Here is my problems: The upward motion for the 3 pt. lower 2 arms is extreemly slow raising, like over 5 minutes to get to the top most point but lowerss very fast. Fluid is full on rear dip stick & tractor is new. My fuel guage won't register anything but empty. Any ideas fellows?
treesawer /forums/images/graemlins/confused.gif
   / Kioti hydraulic & fuel guage problem #3
treesawer,
Some models have a knob under the seat, by the back of your legs, when in the seat to adjust the speed of the 3pt lift arms, you may see if your model has one. As for the fuel gauge, May be a loose connection on the fuel float sensor, or possibly a fuse.
It's a Dk-50, I did adjust that knob below the seat but it only controlled the speed of arms going down not up speed. /forums/images/graemlins/confused.gif
   / Kioti hydraulic & fuel guage problem #5
Does your DK50 have draft and position control. If so try it with the draft control in the least sensitive position.
   / Kioti hydraulic & fuel guage problem #6
DOES IT MAKE A LOT OF NOISE, IF IT DOES ITS SUCKING
AIR. HOSE ON PUMP MIGHT NEED TO BE TIGHTEN
   / Kioti hydraulic & fuel guage problem #7
Did you find the problem with the gauge ? I am not sure but I think my DK 55 gauge is funky as well.
CASE 580N EP BACKHOE (A51246)
CASE 580N EP...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
1831 (A51247)
1831 (A51247)
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
