Kioti hrs
/ Kioti hrs #1
iaintopender
Australia. Cairns
Ford 6640 , 4610. 115-90
Does anyone have a high houred kioti? What sort of hrs can be expected from engine/drivetrain if hay rakeing assuming its serviced properly?
/ Kioti hrs #2
Probably no real answer to this question. Someone will always have a tractor with more hours on it.
Diesel engines and drive trains, regardless of the tractor make, will last a lot of hours when cared for.
Buy it and use it.
/ Kioti hrs #3
I have been looking for Kiotis a while now and have seen em still perking along with 7-900 hrs and I think its still young so longs the maintaince has been good. I think Kioti is where Kubota was 25 yrs ago and there is nothing wrong with them except maybe the weight
/ Kioti hrs #4
Interesting comment. I chose the Kioti over the Kubota BECAUSE of the weight. The Kioti was a lot heavier and weight in a tractor means traction which is what a "trac"tor is about. I know I'm still low hours but at almost 400, I've had no problems.
/ Kioti hrs #5
Interesting comment. I chose the Kioti over the Kubota BECAUSE of the weight. The Kioti was a lot heavier and weight in a tractor means traction which is what a "trac"tor is about......I've had no problems.
Egg- zacly why I chose Kioti over JD, MF, KUBotie, etc. :)
/ Kioti hrs #7
"On my way towards a 1000 hours... "
So am I...at 177 hours :)
There was a thread about this with many replies about a year or so ago in this forum.
Jon
/ Kioti hrs #10
Any of you guys make a cheat sheet for maitenence?
/ Kioti hrs #11
Not yet, but on short list of things to do.
Lets compare lists when done to allow for copying of good ideas.:thumbsup:
Chandler Equipment PT 20' Litter Spreader (A60462)
Chandler Equipment...
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
Informational Lot - Financing (A61307)
Informational Lot...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
