Kioti hrs
/ Kioti hrs #1
iaintopender
Australia. Cairns
Ford 6640 , 4610. 115-90
Does anyone have a high houred kioti? What sort of hrs can be expected from engine/drivetrain if hay rakeing assuming its serviced properly?
/ Kioti hrs #2
Probably no real answer to this question. Someone will always have a tractor with more hours on it.
Diesel engines and drive trains, regardless of the tractor make, will last a lot of hours when cared for.
Buy it and use it.
/ Kioti hrs #3
I have been looking for Kiotis a while now and have seen em still perking along with 7-900 hrs and I think its still young so longs the maintaince has been good. I think Kioti is where Kubota was 25 yrs ago and there is nothing wrong with them except maybe the weight
/ Kioti hrs #4
Interesting comment. I chose the Kioti over the Kubota BECAUSE of the weight. The Kioti was a lot heavier and weight in a tractor means traction which is what a "trac"tor is about. I know I'm still low hours but at almost 400, I've had no problems.
/ Kioti hrs #5
Interesting comment. I chose the Kioti over the Kubota BECAUSE of the weight. The Kioti was a lot heavier and weight in a tractor means traction which is what a "trac"tor is about......I've had no problems.
Egg- zacly why I chose Kioti over JD, MF, KUBotie, etc. :)
/ Kioti hrs #7
"On my way towards a 1000 hours... "
So am I...at 177 hours :)
There was a thread about this with many replies about a year or so ago in this forum.
Jon
/ Kioti hrs #10
Any of you guys make a cheat sheet for maitenence?
/ Kioti hrs #11
Not yet, but on short list of things to do.
Lets compare lists when done to allow for copying of good ideas.:thumbsup:
2017 BOBCAT E50 EXCAVATOR (A63276)
2017 BOBCAT E50...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2024 CASE TV370B SKID STEER (A65053)
2024 CASE TV370B...
