Kioti hrs
   / Kioti hrs #1
iaintopender
Australia. Cairns
Ford 6640 , 4610. 115-90
Does anyone have a high houred kioti? What sort of hrs can be expected from engine/drivetrain if hay rakeing assuming its serviced properly?
   / Kioti hrs #2
Probably no real answer to this question. Someone will always have a tractor with more hours on it.
Diesel engines and drive trains, regardless of the tractor make, will last a lot of hours when cared for.
Buy it and use it.
   / Kioti hrs #3
I have been looking for Kiotis a while now and have seen em still perking along with 7-900 hrs and I think its still young so longs the maintaince has been good. I think Kioti is where Kubota was 25 yrs ago and there is nothing wrong with them except maybe the weight
   / Kioti hrs #4
Interesting comment. I chose the Kioti over the Kubota BECAUSE of the weight. The Kioti was a lot heavier and weight in a tractor means traction which is what a "trac"tor is about. I know I'm still low hours but at almost 400, I've had no problems.
   / Kioti hrs #5
Interesting comment. I chose the Kioti over the Kubota BECAUSE of the weight. The Kioti was a lot heavier and weight in a tractor means traction which is what a "trac"tor is about......I've had no problems.
Egg- zacly why I chose Kioti over JD, MF, KUBotie, etc. :)
   / Kioti hrs #7
"On my way towards a 1000 hours... "
So am I...at 177 hours :)
There was a thread about this with many replies about a year or so ago in this forum.
Jon
   / Kioti hrs #10
Any of you guys make a cheat sheet for maitenence?
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2014 DRAGON  130BBL VACUUM TRAILER (A52472)
2014 DRAGON...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
