Kioti Fluids List (from dealer)
   / Kioti Fluids List (from dealer) #11
I'm also due for a engine oil change, thinking of going with the Rotella synthetic this time, I've have always used the standard 15-40 Rotella before.
   / Kioti Fluids List (from dealer) #12
Yes, I run Rotella T-6 synthetic 5w-40 year round and have been for the past 16 years - 2000+ hours
This!
I use it in my Ford F-150, Woodmizer mill/Kohler engine, Motorcycles, Vespa scooter AND my Kioti tractor. It is a very popular oil.
Buy it on sale, get the rebates then do the cap codes for points. I get enough points alone, to eat out at Red Lobster free once each year. Walmart. It's so popular at wally I have resorted to web buying then store pickups as the shelves remain empty.
lets hope this doesn't hang on to become the dreaded you know what...
   / Kioti Fluids List (from dealer) #13
The Shell Donax TD that's on the list has changed to Shell Spirax md/s4txm about two years ago. An easy hydraulic fluid to get is from Tractor Supply. Their "Premium" Hydraulic fluid is a multi viscosity fluid and meets the specs. Other members have used it with good results. That's what I'm going with on my next change. I have been using Rotella 5W-40 full synthetic engine oil year round because I can go from single digits in the Winter to 80 plus in the Summer. Enjoy the new toy.
I'm going to switch over to the Tractor Supply premium next change. I used Shell Spirax last time. It is hard to find in stores so I had to go to a distributor. It sill cost me $88 for 5 gallons. Crazy.
   / Kioti Fluids List (from dealer) #14
I use Shell Rotella T6 for the engine year round and the TSC premium hydraulic fluid for the trans and front end. No issues with either and plan to stay that way.
Thanks for all of the input on fluids. Filters have been ordered and will pick up the fluids next week. Just need to find the time after that.
What are y'all using for a drain pan for the hydraulic fluid?
   / Kioti Fluids List (from dealer) #16
A 5 gallon bucket. I syphon what I can, and I have to put the plug back in at least one time during the drain down. Mine holds 16 gallons.
   / Kioti Fluids List (from dealer) #18
Rotella T6 can't go wrong. Find it on sale at Wally World and buy up a couple of changes ahead of time. I change my oil & filter every 75 hours which typically coincides with my yearly use.
   / Kioti Fluids List (from dealer) #19
I use a big plastic "tote" . It holds a bit over 10 gallons. It is hella heavy to drag out from under the tractor, but it holds it all. I use a smaller drain pan for the front differential drains near the front wheels, and you can use a smaller one also for the rear final drive drains on each side near the rear wheels. They are about a gallon each as I remember. But for the big drain plug in the middle of the transmission, You don't want to be trying to change containers, as that stuff comes out with a whoosh. Providing you remove the fill plug up top to allow air in quickly. So that is 5 drain plugs to get and two reservoirs to refill.
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2021 CATERPILLAR 226D3 SKID STEER (A52707)
2021 CATERPILLAR...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
