Kioti exhaust problem w/FEL
   / Kioti exhaust problem w/FEL #1
Gusss
Texas
Koiti LB1914
I just bought a 2003 LB1914 Kioti with 96 hours on it.
The lady I got it from did not change anything so everything is as the dealer set it up.
It has a Kioti FEL and the tractor was pressure washed before I got it, so it was clean.
A couple hours of operating it hit me with one thing. The exhaust turned to the outside of the tractor blows on the arm of the FEL and right onto the hydrolic lines! This looks like a recipe for a problem.
Turning the end pipe up insures that I constantly get a face full of diesel every time I move forward. If I turn it down, it blows on a lower frame.
What did Kioti intend to do with the exhaust with the FEL installed? Was a different end pipe upgrade left off? I would suspect the end pipe on the muffler should have a crook in it and exhaust down. Or a protection plate on the frame and hydrolic lines were left off.
Thanks for any feedback on this.
Gus
   / Kioti exhaust problem w/FEL #2
my exhaust has caused my loader arms to turn black after 2 years and over 300 hours. No problem for me, but I am unsure of any danger in your particular model. I also don't "wash" my tractor. I do periodically hose it off after it gets too muddy for safety.
   / Kioti exhaust problem w/FEL #3
The exhaust coming out of the pipe is not that hot so I would not worry about the hydraulic lines. My CK20 does leave a little black soot on the loader arm that I power wash off every 20-30 hours or so but that is hardly a problem.
   / Kioti exhaust problem w/FEL #4
Mine was doing the same thing. I just rotated the muffler up 90 degrees. it keeps the exhaust from blowing dirt into the air filter. You can do a search for LB1914 tractors and see a picture of one with the muffler turned up.
Jim
   / Kioti exhaust problem w/FEL #5
my '94 lb1914 muffler goes straight up with a kl102 loader. the flange with 4 bolts appears to be so that it could be turned 90 degrees as others said.
2019 Caterpillar 249D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TANK MANIFOLD (A55745)
