Kioti DS3510 with AL 36 FEL 4 in 1 bucket fitted.
   / Kioti DS3510 with AL 36 FEL 4 in 1 bucket fitted. #1
Wilgadene
Childers Queensland Australia
Daesong Kioti Ds3510
I have the above tractor and the solenoid that operates the hydrolics for opening and closing the bucket has failed. Does anyone know where I can buy a replacement solenoid at a reasonable price. The kioti dealers in Australia are asking $800 AUD.
Cheers and thanks for any advise.
   / Kioti DS3510 with AL 36 FEL 4 in 1 bucket fitted. #2
Do you have a part #?
$800 is a lot for a solenoid.
   / Kioti DS3510 with AL 36 FEL 4 in 1 bucket fitted. #4
How about just using the rear remotes to control the bucket? Otherwise you should be able to get a full new diverter valve for $800. Doesn't sound right as a solenoid shouldn't cost more than $200 or so. Is the dealer just going to swap out the whole diverter/third function valve kit??
Thanks IT that may be a way around it, the dealer only quoted on the solenoid but I do wonder how much knowledge they had of the part I need and may well have quoted a full replacement.
   / Kioti DS3510 with AL 36 FEL 4 in 1 bucket fitted. #7
How about a photo of this thing? Does it have a brand name or model number on it? Where is the valve located? Does it work by switching the function of the curl circuit or does it use a three-position (up-neutral-down) rocker switch?
You can get a quality valve for $200-300 but you'll need to match the port threads and mounting holes for a clean installation.
The only info printed on the item looks like Lisa Ireland Pat'd & Pat. Pend.
Couple of pics attached
   / Kioti DS3510 with AL 36 FEL 4 in 1 bucket fitted. #10
Well, that is indeed a diverter valve (as opposed to a third function valve). I haven't seen one that looks quite like that before or one mounted on the torque tube, maybe that's just my limited exposure. Can you expand on what you mean when you said the solenoid failed?
There are two parts to these valves: a hydraulic "spool" that does the actual switching of the flow and an electrical solenoid that moves the spool (against spring pressure) from the default position to the other position. If only the electrical coil has failed, it can easily be replaced if parts are available. In fact, these valves can be ordered with any of several coils for different applications (e.g. 12v, 24v, 110vac, etc.) Do you know if the spool is jammed or if the electrical solenoid has failed?
You can certainly replace the complete solenoid valve but the trick will be ordering the one that mates with the existing fittings and mounting bracket. Here is an example of the kind of valve I see these days in the US: http://apps.boschrexroth.com/products/compact-hydraulics/cdv-catalog/pdf/vs151-152-155.pdf
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
