Mowing Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE???
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #71
What part of the design failed and why? Is this design used elsewhere? I am told is was stolen from Kubota.
Yeah, but you are a retarded Troll..... ;)
You'd hafta answer CalG's question first to answer that.
Either the design for keeping the fluid cool under heavy load failed which overheated the fluid and destroyed the PTO clutch.
Or, the PTO clutch began slowly failing, slipping, creating heat and overheating the fluid.
Take your pick.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #72
How many other failures have you heard of:confused3:? If it was a design fault Eric would of trashed his long ago:eek:. And Kapper too.;)
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #73
And I will ignore the troll comment.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #74
Not sure. I don't research Kioti failures. Although some posters on this thread actually believe this is all a big conspiracy. :)
We all use/stress our equipment in different ways. Some users more than others. When equipment fails it's generally accepted as "equipment failure" rather than "operator failure". I read the OP's posts and at least think I understood what was written. So I can only base an opinion on that information. Otherwise I'd be calling the OP's integrity into play. I have no support for taking that stand.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #76
He bought this used at 600 hours and you have no idea how it was used and neither do I. BUT it is a Kubota design so anything is possible.:D
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #77
Troll.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #78
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #79
Here Murph. Give you something to look at so you can get your mind off being a Troll. :cool:
Part of my friend's harvesting operation.
   / Kioti DK55 TRANS WAS BOILING HOT after bush hogging WHAT HAVE I DONE??? #80
Thanks my friend. He has a fortune in equipment. What is his BPA?
Bunker Rake (A59228)
1987 Chevrolet R3500 (A57148)
1987 Chevrolet...
15 35ft. Commercial Black Metal Light Poles (A56858)
15 35ft...
24 x 60 Lodge and Shipley Lathe (A59213)
24 x 60 Lodge and...
2014 Kubota RTVX 900 (A57149)
2014 Kubota RTVX...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
