Loader Kioti DK50SE HST FEL Specs.
   / Kioti DK50SE HST FEL Specs. #11
Not a total hijack since we're talking FEL specs.
Does anyone know the proper torque for the FEL line hydraulic fittings? I have one that leaks constantly but it seems to be tight. I may have to pull it apart in order to get it stopped.
We always went hand tight then mark the nut, Go one flat more with a fitting wrench.
   / Kioti DK50SE HST FEL Specs. #12
Thanks Murph. For something that looks so easy, it's a B to get access with 4 lines running in parallel. My biggest fear is in twisting/crushing an adjacent line or stripping the connector threads.
   / Kioti DK50SE HST FEL Specs. #13
Maybe the OP and another DK50SE owner could design and conduct a few simple stopwatch tests and compare notes. For example, they could measure the time from max dump to max curl (and the reverse) at full joystick throw. I'd be happy to do it but I have the wrong tractor/loader.
   / Kioti DK50SE HST FEL Specs. #14
That seems like a good idea, but I have the same problem as you.. I know mine is faster.
   / Kioti DK50SE HST FEL Specs. #15
I'd be happy to participate if I can ever find time to get to my property where the tractor is.
   / Kioti DK50SE HST FEL Specs. #16
It sounds like an adjustment issue on your joystick. Is there another dealer close by? Go and ask to test one on there lot to see for yourself. If it performs totally different than ask them if they will repair yours under warranty.
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2012 International Prostar (A56435)
2012 International...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2017 Ford F150 Single Cab Pickup Truck (A55973)
2017 Ford F150...
