IH3444
Veteran Member
- Joined
- Jan 10, 2004
- Messages
- 2,075
Does anyone know if Kioti uses the same transmission, and 3 speed range rear axle in the DK series of 45, 45S, 50, 65, and 65S tractors. I do understand that the "S" series have an additional syncro on the mainshaft. What exactly does this additional syncro do, that the earlier transmissions didn't. I am particularly interested in the fact that the Kioti appears to have a much more massive rear in it with heavier shafts exiting the rear housing. I felt that if the same massive unit is used in all models, that it must be very "bullet proof" to also handle 65 ponies of engine torque being put through it. Many other brands just don't look as massive, and after checking with a magnet I find that the material is cast steel. A big plus for durability in the extreme long haul as far as I'm concerned. Does anyone know what size the rear axles are? They even look larger than the axles on the New Holland TC48, and 55 tractors. Thanks for any answers, IH3444
