Kioti DK45 owner
/ Kioti DK45 owner #1
kkimes
Harrison, AR
Kioti
I just bought a 2002 Kioti DK45 tractor. I'm having trouble with (shuttle shifter which puts tractor into forward or reverse) jumping into neutral when I'm in 4th, 3rd, or 2nd gear. Has anyone seen this before and if so how do I fix it.
Thanks.
kk
/ Kioti DK45 owner #2
Did you follow the advice in the last thread you posted in?
/ Kioti DK45 owner #4
Welcome to the forum Kent. Keep all your eggs in one basket. Interaction is key here.
/ Kioti DK45 owner #6
Several years ago, when my 2006 DK45 was still under warranty (thankfully!), mine started popping out of reverse. It turned out to be a bent shift fork. After replacement, my dealer said the new fork was visually much beefier than the original. I don't know if that is your problem; if so, it involves a lot of labor to tear into its guts and replace the fork (mine is a cab version, so even more hassle).
Bob
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
10ft. Fork Extensions (A59228)
10ft. Fork...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Ford F-550 Liftmoore 4x4 6036 3 Ton Crane Mechanics Truck (A59230)
2001 Ford F-550...
