kioti DK40SEH loss of hydraulic power arms won't go up much
   / kioti DK40SEH loss of hydraulic power arms won't go up much #1
blurry
Auburn, ny
DK40SEH
Hi guys. I'm in a pinch and could use some help. Just bought a waterfront lot and it needs to be cleaned up stat (long story). I'm on a DK40SEH.
symptoms: drives fine on flat surface. occasional loss of power which I believe is related to incline. loader arms go up a couple feet and stop - I can hear a pump running but no movement. I tried to lift the front wheels with the grapple and there appears to be very little power (went down and didn't even try to lift the front wheels). I added about a gallon of fluid through the red vent tube (removed first :) ) - dipstick is reading at the high end of the tick marks. checking with the engine off and fluid warm.
I have a small leak on the aux hydraulic lines and which is how the level got low.
any ideas what I should be doing here? I'm feeling rather out of luck right now :(
thanks!
I should say the engine sounds great :)
just noticed the three point isn't going up all the way either....
   / kioti DK40SEH loss of hydraulic power arms won't go up much #4
Your rear remotes accidentally engaged?
remote is not engaged, checked the remotes (connected to grapple) and grapple is moving though slower than I thought it did.
I did notice that if I put the loader down (not in float) and curl it to lift the front end it is extending the loader lift arms which it shouldn't - then if I try to lift the loader you have to hold it for a while before the arms raise - then they stop really low like before.
   / kioti DK40SEH loss of hydraulic power arms won't go up much #6
Try unplugging and then plug in all 4 couplers beneath the right step at the control valve. Make sure you get them seated back. Give that a try. Do this with the engine off of course.
holy crap - you are our genius! one of the lines got disconnected - wow, thank you!!!!!!!!!!!!!!!
for anyone that has an issue like this - visually I couldn't tell the line was loose - I checked because @k0ua asked to unplug and re-connect them.
man, you guys and gals are great!
   / kioti DK40SEH loss of hydraulic power arms won't go up much #9
Not a genius. Heard of this problem before. I just took note and remembered. :)
2011 Crown Victoria Sedan (A51694)
2011 Crown...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2021 New Holland C327 Compact Track Loader (A53472)
2021 New Holland...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2022 KMC 21-37-HD LOT NUMBER 177 (A53084)
2022 KMC 21-37-HD...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
