kioti DK40SEH loss of hydraulic power arms won't go up much
   / kioti DK40SEH loss of hydraulic power arms won't go up much #1
blurry
Auburn, ny
DK40SEH
Hi guys. I'm in a pinch and could use some help. Just bought a waterfront lot and it needs to be cleaned up stat (long story). I'm on a DK40SEH.
symptoms: drives fine on flat surface. occasional loss of power which I believe is related to incline. loader arms go up a couple feet and stop - I can hear a pump running but no movement. I tried to lift the front wheels with the grapple and there appears to be very little power (went down and didn't even try to lift the front wheels). I added about a gallon of fluid through the red vent tube (removed first :) ) - dipstick is reading at the high end of the tick marks. checking with the engine off and fluid warm.
I have a small leak on the aux hydraulic lines and which is how the level got low.
any ideas what I should be doing here? I'm feeling rather out of luck right now :(
thanks!
I should say the engine sounds great :)
just noticed the three point isn't going up all the way either....
   / kioti DK40SEH loss of hydraulic power arms won't go up much #4
Your rear remotes accidentally engaged?
remote is not engaged, checked the remotes (connected to grapple) and grapple is moving though slower than I thought it did.
I did notice that if I put the loader down (not in float) and curl it to lift the front end it is extending the loader lift arms which it shouldn't - then if I try to lift the loader you have to hold it for a while before the arms raise - then they stop really low like before.
   / kioti DK40SEH loss of hydraulic power arms won't go up much #6
Try unplugging and then plug in all 4 couplers beneath the right step at the control valve. Make sure you get them seated back. Give that a try. Do this with the engine off of course.
holy crap - you are our genius! one of the lines got disconnected - wow, thank you!!!!!!!!!!!!!!!
for anyone that has an issue like this - visually I couldn't tell the line was loose - I checked because @k0ua asked to unplug and re-connect them.
man, you guys and gals are great!
   / kioti DK40SEH loss of hydraulic power arms won't go up much #9
Not a genius. Heard of this problem before. I just took note and remembered. :)
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
2019 Toyota Corolla Sedan (A51694)
2019 Toyota...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
