kioti dk40se will not turn over
   / kioti dk40se will not turn over
Well I got to drag my tractor all over my property yesterday.
I put it in high range 2 gear. The tires on the tractor would not
Turn. I then went to 3 gear the tires would turn. I drug it about five hundred
Yards with no luck. This tractor only has around 70 hrs on it. I really do not
Want to split it if I can avoid it. I also engage the front differential. Any ideas?
Should I start a new thread (clutch will not disengage)?
   / kioti dk40se will not turn over #22
Maybe a dumb question but, you did have the clutch pedal locked down, yes?
A new thread with a more precise title is a good idea.
Yes the clutch pedal was down.
I moved this post to a new thread(Dk40se stuck clutch)
   / kioti dk40se will not turn over #25
Drive tractor, get it good and hot. Then block the clutch pedal down. Let it sit overnight. Then do it again.
Alot of times the dissimilar materials will allow the clutch and flywheel to separate.
You have an extreme circumstance that is for sure.
You also might want to take the starter back off and aim a heater at the hole in the bellhousing so you can make sure it is dry.
Leave clutch blocked down while doing this.
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
Kubota LX2620 (A53317)
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2263 (A58376)
2263 (A58376)
