Kioti DK35 4wd switch fault/replacement Ireland
   / Kioti DK35 4wd switch fault/replacement Ireland #1
jamesmb
kioti dk35
Hi!
I have a faulty 4WD switch which is mounted at my left heel. I was wondering How I could replace this faulty push button switch with a simple toggle switch? how do I Identify which wires need to be connected to engage 4WD? Has anyone out there tried? there are 5 wires into the switch so Identifying them isnt as simple as it other wise might be! I can get pictures up if thats a help to anyone!It would be great if the dash indicator also came on but not totally necessary! thanks in advance, Regards James
   / Kioti DK35 4wd switch fault/replacement Ireland #2
You really need a wiring diagram to sort out your problem. Personally, I would just replace the switch with an oem.
Thanks RJCorazza. the tractor is a US import so finding a switch is not time or money efficient as it would have to come from the States, and I cant seem to find the exact one. I will put up images.
It seems the red and black wire are just for a back light on the switch so the switch has 3 wires, my guess is that one is power in and one is power out to the light on the dash and the other is power out to the solenoid. I will check with a multi meter and see how it goes. I will put up images incase it helps.
first pic is plug on tractor last pic is the switch Im thinking of installing!
   / Kioti DK35 4wd switch fault/replacement Ireland #5
Is that a momentary contact push button switch, or a latching push button switch that releases on the 2nd push?
07wingnut, Thanks for the question. Its in bad working condition but seems to be latching. I will check it more closely next time Im beside it...I see your point tho, If it only needs a jolt of voltage to actuate, then the toggle switch isn't a suitable replacement.
   / Kioti DK35 4wd switch fault/replacement Ireland #7
I'd suspect that push on is a latching switch.
Like push for on push again for off.
If actually so then the toggle would work.
Best is take a meter to the old switch and prove it out.
Hint, do U feel a clicking when push in?
The wire gauge might also be an indication, looks to be about 16g that suggests a 'hold' circuit while smaller would suggest a pulse.
Thanks a lot PILOON, makes sense. Im shocked there is nothing on here about them to be honest, they seem almost designed to fail and are also in a bad spot behind your heel on the floor. If I can make it work I hope to find a space for it on the dash. I will hopefully get a chance to work on it during the week.
It is latching; badly! hoping to get some time with the multimeter tomorrow.
2006 CMI C125-1 Ride-On Forestry Mulcher (A49461)
2006 CMI C125-1...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
2013 John Deere 35D Mini Excavator (A49461)
2013 John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
