Kioti DK 35 P.T.O power ?
   / Kioti DK 35 P.T.O power ? #1
n1wjr
GRANTHAM,N.H.
KIOTI DK 35
HI ALL, Does any one know what the HP is for the pto on a kioti dk 35 ?
I Dont see it in the book,I know its a 35 hp tractor but what is the pto power rating?
thanks
matt
   / Kioti DK 35 P.T.O power ? #2
thank you, I did not think of KIOTI HOMEPAGE
I was looking at some implements and they had pto min. hp, so i got the book out and did not see it so i just got on here and asked.
thanks agin
matt
   / Kioti DK 35 P.T.O power ? #4
What implements are you looking to buy?
   / Kioti DK 35 P.T.O power ? #5
I can tell you what implements work on my DK 35, if you let us know what you looking for.
looking to buy a rotary cutter(brush hog) not sure 5 or 6 ft,and mabey a tiller would it handle a 5 foot tiller ?
also what brands are best?
I dont have lots of fields to mow,but i do go to a local farmers auction and some times they have good deals on used ones.
thanks
matt
   / Kioti DK 35 P.T.O power ? #7
I just purchased a CK35 and I'm pulling a heavy duty 66" First Choice tiller no problem. Bought it with the tractor.
60 rotary cutter will be no problem either, I'm waiting on an orange one to arrive at my dealer.
The DK is a heavier tractor with higher capacities, so you'd have no problem with these.
   / Kioti DK 35 P.T.O power ? #8
For a brush mower, a 5' heavy duty, or a 6' standard should work fine.
I run a King Kutter 6' brush mower on mine without any problem.
A 60" or 66" tiller will work. (a 60" model should be able to side shift slighly to cover tracks on at least one side).
As far as tillers. There are a lot of nice tillers available. I would recomend one with 6 tines per flange and a slip clutch.
I personally think that gear drive vs chain drive in a tiller makes little to no differant in Quality/reliabilty. But thats my opinion..
ATV (A59231)
ATV (A59231)
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
1990 35 Ton Phelan Low Boy (A57453)
1990 35 Ton Phelan...
2018 HINO 338 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 HINO 338 26FT...
Toro Groundsmaster 400-D (A57453)
Toro Groundsmaster...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
