Kioti CS2510 Dies/won't keep running/rough starts
   / Kioti CS2510 Dies/won't keep running/rough starts
Sure enough that was it. Got the new fuel pump installed and the tractor started right up. Thanks for all your help; I learned a lot!
MowinLife
   / Kioti CS2510 Dies/won't keep running/rough starts #12
Good for you, now you can get some tractor time. Pretty easy fix.
   / Kioti CS2510 Dies/won't keep running/rough starts #13
It was a pleasure reading how you all successfully analyzed the fuel problem issue, and eventually isolated the bad fuel pump as the problem. I certainly learned useful knowledge from this thread. Much appreciated guys. Good team work.
2018 Altec DC1317 Towable Brush Chipper (A55851)
2018 Altec DC1317...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2020 Deere 50G (A53317)
2020 Deere 50G...
LOWRY 2020SB HD 7' DISC HARROW (A57192)
LOWRY 2020SB HD 7'...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
