Kioti cs2410
/ Kioti cs2410 #1
Michjim6464
Lansing, mi
Looking
Hello, I have been looking for info on the semi new cs2410 with limited success.
So, I was wondering if there are any current owners on here that can give some feed back?
What do you like about it?
Any complaints?
Is 12,600.00 a good price for a cs2410 with FEL and MMM?
Thank you.
/ Kioti cs2410 #2
I have had a cs2410 since last summer and love it. The Main purpose I bought it for was mowing with the mid mount mower and it does that in half the time as my 54" garden tractor. I spread 30 yards of gravel with it and for how small the cs is I was very impressed. The cs could pull a full 4' box scraper over flowing with gravel in high gear (low gear is more desired for this). As for as anything that I don't like I have yet to find any.
/ Kioti cs2410
Thanks for the feed back.
Anyone else had positive reviews?
Anyone in the Mid Michigan area deal with Michigan Iron and Equipment? (Only talked to them once but seemed to know their stuff)
/ Kioti cs2410
I have another question......
For smoothing out a 150 dirt driveway should I get a rear blade or box blade (4ft)???
/ Kioti cs2410 #7
Boxblade would work better in my opinion. Once the gravel has been packed down the box blade will pull the fine material back up and mix with the rock to make it look like you got another couple loads of class a gravel. A rear blade was always the way, but honestly they seem to be taking a back seat for gravel work compared to the box blades now. The rear blade usually does not have enough weight to dig down into the hard packed gravel and pull much up.
/ Kioti cs2410 #9
For smoothing, box blade. For trenching, backblade. For smoothing and crowning the center, a rake. I like the rake best for routine refinishing. If there are a lot of pot holes the box would be the way to go.
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
2022 EZ-GO ELITE...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
2019 CATERPILLAR 336 EXCAVATOR (A65053)
2019 CATERPILLAR...
New - Front mount rototiller
New - Front mount...
