Oil & Fuel Kioti Craft and HST oil change
   / Kioti Craft and HST oil change #1
ERE
Northern VA
Kioti CK25 HST
The pics are Wylie and I helping a neighbor do a precision lift of a pre assembled post and beam for his house entry way.
I did my second change of HST oil today and did something that made my life a easier (for a change). I suspect that others have figured this out but for those of you who are looking forward to their first change, try this. I drained the 38 quart sump by pulling the plug on one of the rear wheel gear sumps first. That controlled the drainage to what I could hold in all in my five gal drain pan. Then I pulled the main plug on the bottom and got another 3 or 4 gal out. The first time I did it, I made a mess of my hand/arm by putting the main drain plug back in to stop the flow before I overflowed the drain pan. This was much easier and I had no worries about a mess on the garage floor.
OK, so I don't know how to attached pics. I used the upload procedure and it obviously didn't work.
   / Kioti Craft and HST oil change #3
Ere,
This may be the long way around, but i re-size my pics, then put them on Photobucket.com. When posting, "copy" the "direct link" pic on photobucket, then click on the little yellow mtn scene above here on tbn, "paste" the pic in the box that comes up & it should show up on your post before you post it. If a box w/ a red X shows up you used the wrong photobucket pic.
I fumbled with this for some time before the light came on........
RD
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55314)
2025 Mahindra 6075...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
Kubota RTV X900 (A53317)
Kubota RTV X900...
