Kioti Clutch Cable
   / Kioti Clutch Cable #1
mulespb
Springfield, MO
Kubota L3400HST, JD 4020, Farmtrac 435, Kioti RX6010C
I bought a Kioti RX 6010C last year with 200 hours on it and I'm not happy. I also own a Kubota L3400HST and a Farmtrac 435 and the tractor is not nearly as well made as others I'm used to. The Clutch cable recently broke and I'm waiting for a new one.....only $30 cable but I'm shut down till I get the new cable on. No way a 280 hour tractor should snap a clutch cable. I also have a problem with the tractor getting hot under a load with a 8 ft twin spindle bushog.......even with a clean radiator. It'll cool down quickly after I take the load off it but not acceptable for a 60 HP utility tractor.
So far I'm not a fan on Kioti.......saw where someone else snapped a clutch cable at 300 hours.......better spend a little more and buy Kubota.
   / Kioti Clutch Cable #2
I bought a Kioti RX 6010C last year with 200 hours on it and I'm not happy. I also own a Kubota L3400HST and a Farmtrac 435 and the tractor is not nearly as well made as others I'm used to. The Clutch cable recently broke and I'm waiting for a new one.....only $30 cable but I'm shut down till I get the new cable on. No way a 280 hour tractor should snap a clutch cable. I also have a problem with the tractor getting hot under a load with a 8 ft twin spindle bushog.......even with a clean radiator. It'll cool down quickly after I take the load off it but not acceptable for a 60 HP utility tractor. So far I'm not a fan on Kioti.......saw where someone else snapped a clutch cable at 300 hours.......better spend a little more and buy Kubota.
That a good thought
   / Kioti Clutch Cable #3
Why start two threads with the same issue?If you don,t like your Kioti tractor sell it and move on.After all you bought a used tractor and put a whopping $30 bucks into repairs.I would be jumping up & down joy for a $30 repair.
   / Kioti Clutch Cable #4
.... So far I'm not a fan on Kioti.......saw where someone else snapped a clutch cable at 300 hours.......better spend a little more and buy Kubota.
... so are you actually complaining that you broke a $30 cable on a used tractor you bought? You expect to have no downtime on a tractor? I'm not sure but you might just have some unrealistic expectations. Best to stick with a brand you have confidence in...
   / Kioti Clutch Cable #5
I hate all the whiners and brand bashing here, but I would expect ANY clutch operating cable on a tractor of that age to last more than 280 hours regardless of how many owners it has had in that time.
I think the OP has a valid point, and as a parts manager at a Kioti dealership, I'm interested to see if this turns out to be a random failure or an endemic shortfall in part selection on Kioti's part. Right now, I have yet to sell a replacement cable for an NX.
$30 clutch cable no big deal.............being down a week while hay gets wet........very big deal. Are you a Kioti salesman?
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
2011 CAT 430E BACKHOE LOADER (A50854)
2011 CAT 430E...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51242)
2024 INGERSOLL...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
