Kioti CK4010SE - RPM's won't increase past idle
   / Kioti CK4010SE - RPM's won't increase past idle #1
dvleemin
Hi,
I have a 2022 Kioti CK4010SE with about 40 hours on it, and today I could not get the RPM's to increase. With this tractor, when you start it, regardless of the throttle lever position the RPM's start out really low. So usually you just move the throttle leave up and then down, and then the RPM's increase to a normal operating level. Today though moving the throttle lever does nothing and so the tractor won't increase the RPM's at all. I'm at a complete loss as to why this is suddenly happening.
Anyone have any ideas?
Darryl
   / Kioti CK4010SE - RPM's won't increase past idle #2
Hi,
Darryl
Cold weather, low idle until it warms up. Other option is looking to see if the throttle cable came loose. Does the end by the injector pump change?
   / Kioti CK4010SE - RPM's won't increase past idle #3
Two year old tractor with only 40 hours? Wow, work that tractor more. Has it had its first service? It’s due if not done. While it’s getting serviced have the technician check the operation of the throttle cable. From dash lever to injector pump. Yes it’s not good to scream a cold engine, but you should be able to adjust it to halfway to warm up better. It has warranty right? Keep us posted.
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
