Kioti CK4010SE - RPM's won't increase past idle
   / Kioti CK4010SE - RPM's won't increase past idle #1
dvleemin
Member
Hi,
I have a 2022 Kioti CK4010SE with about 40 hours on it, and today I could not get the RPM's to increase. With this tractor, when you start it, regardless of the throttle lever position the RPM's start out really low. So usually you just move the throttle leave up and then down, and then the RPM's increase to a normal operating level. Today though moving the throttle lever does nothing and so the tractor won't increase the RPM's at all. I'm at a complete loss as to why this is suddenly happening.
Anyone have any ideas?
Darryl
   / Kioti CK4010SE - RPM's won't increase past idle #2
Hi,
Darryl
Cold weather, low idle until it warms up. Other option is looking to see if the throttle cable came loose. Does the end by the injector pump change?
   / Kioti CK4010SE - RPM's won't increase past idle #3
Two year old tractor with only 40 hours? Wow, work that tractor more. Has it had its first service? It’s due if not done. While it’s getting serviced have the technician check the operation of the throttle cable. From dash lever to injector pump. Yes it’s not good to scream a cold engine, but you should be able to adjust it to halfway to warm up better. It has warranty right? Keep us posted.
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
Toro Z Master Mower (A50324)
Toro Z Master...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
Fire Place Mantel (A49462)
Fire Place Mantel...
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
