Kioti CK35 HST Hydraulic 3/8" Quick Connect Fitting O-Ring Size
   / Kioti CK35 HST Hydraulic 3/8" Quick Connect Fitting O-Ring Size #1
kiotick35hst
Bowdoin, Maine
Kioti CK35 HST
I just wanted to provide information for anyone who owns a Kioti CK35 HST. However this information should apply to anyone with standard 3/8" quick connect female fittings as the dealership told me they are standard 3/8" hydraulic quick connects. The O-ring that fits inside the female side of the coupling is an AS568-114. Currently I'm using 70 durometer O-rings but have purchased 90 durometer o-rings because the 70's seem to be failing occasionally. However, I have not replaced the back up ring yet but that is because I just confirmed the o-ring size about an hour before this post. If I do use the 90 durometer O-rings, I'll try to remember to update this post. Also, I purchased the O-rings from oringwarehouse.com. They seem to have the best prices by far. Good luck to anyone having leaking hydraulics. To anyone with a CK35 HST, my leaking hydraulics are two of the four hoses that go to the FEL. I disconnected those hoses once and eventually they started to leak. The o-ring is the issue but the back up rings may need replacing too.
Good Luck
I wanted to update my previous post. Use 90 durometer O-rings as the last much longer. As a matter of fact, the 70 durometer O-rings started leaking after a few hours of use. I replaced them 90 durometer o-rings back in May/June of 2013 and as of October 9th, 2013 they have not started leaking.
Good Luck!!!
Here we are, May 2014. The 90 durometer o-rings that I installed last May, in the post above, have still not failed.
   / Kioti CK35 HST Hydraulic 3/8" Quick Connect Fitting O-Ring Size #4
Thanks for the occasional update. Good to know what works.
2019 Toyota Corolla Sedan (A51694)
2019 Toyota...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
