Kioti CK30 guage issues
/ Kioti CK30 guage issues #1
bzimmel
Buford, GA
Kioti CK30
I put this on the Kioti section, too, but both my fuel guage and my temp guage quit working at the same time. Anyone have an idea of a quick diagnosis/fix?
/ Kioti CK30 guage issues #2
Haven't heard of similar incidents. No idea, here, but thought you deserved at least a response. ;)
/ Kioti CK30 guage issues #3
Sounds like a grounding problem. If the tractor starts OK, and the headlights work OK, I
would be looking at the connectors on the gauge cluster, and/or the key-starter switch. The
cluster is easy to remove. You may have dirt or corrosion in the contacts. If not, check
for ground and power at the female side of the connectors, once removed.
/ Kioti CK30 guage issues #4
Have you checked your fuses, not sure about "your" machine but mine gets power from one fuse on both gauges, they also share the same ground.
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
Deere 50D (A60462)
Deere 50D (A60462)
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
Ford 8510 (A53317)
Ford 8510 (A53317)
