Kioti CK27 door latch wont open from the outside
   / Kioti CK27 door latch wont open from the outside #1
Looking4new
Super Member
Northern Ontario, Canada
2012 Kioti CK27HST w/cab
The door latch on my Kioti CK 27 is giving me a real hard time opening from the outside. I've taken the window dressing off the latch on the inside and found the latch adjustment button has a bolt with a recessed lock nut on it. I think a work around would be to drill a hole in the plate that actuates the latch on the inside and put a 1/4" bolt and nut and that would take up the slack. Rather than taking the whole latch assembly apart just to turn the plunger bolt out a 1/4". I think that would work, what do you guys think?
ASSET DESCRIPTIONS & CONDITION (A50505)
ASSET DESCRIPTIONS...
2014 JLG G6-42A Telehandler (A50490)
2014 JLG G6-42A...
CASE DAVID BROWN 990 TRACTOR (A50459)
CASE DAVID BROWN...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50505)
2017 FREIGHTLINER...
Concrete Buggy (A49346)
Concrete Buggy...
Grove 4x4 Rough Terrain Hydraulic Crane (A49346)
Grove 4x4 Rough...
