Kioti ck2610 manual fuel shut off
   / Kioti ck2610 manual fuel shut off #1
Sheldon Hamblin
2016 Kioti CK2610HST with loader , 2014 John Deere X310 w/mower deck and snowblower,
Has anyone installed a manual fuel shut off in the fuel line just before the filter ?
I would think this would be easier than putting a clamp on the line when changing the filter.
   / Kioti ck2610 manual fuel shut off #2
The fuel filter housing on your tractor doesn't have a small lever up top? Usually there is a small lever that it's indeed a shut off valve.
   / Kioti ck2610 manual fuel shut off #3
As far as I am aware, there is no manual fuel shutoff on the Kioti CK Series of tractors. When I changed my fuel filters, i just temporarily crimped the fuel line, prior to filter change. However, a proper fuel shutoff maybe a better way to go for changing filters. Just need to think why Kioti failed to put one on the tractor to begin with. Can such a fuel shutoff be a point of future constrictions or blockage.
Attached is the fuel line for my CK4010:
I just checked my machine to be sure, there is a valve to help prime the filter, but I can find no shut off.
Thank you for replying. I wanted to know if there was a reason there was no shut off before I put one in.
I still have to find the ID before order one.
   / Kioti ck2610 manual fuel shut off #5
Running the pump dry (if you forgot to open the valve) on a regular basis would probably damage it, and it may be a pain to re-prime the system. If you're just using it for filter changes, then there's probably little downside.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2019 FREIGHTLINER CASCADIA (A52577)
2019 FREIGHTLINER...
