Kioti ck25 slow in medium range
/ Kioti ck25 slow in medium range #1
Mikeslawn
Alliance,ohio
Bobcat ct225 / kioti ck25
I have a kioti ck25 with 350 hours. It has gotten alot slower in medium range. I change all fluids and filters regularlly. Please help!
/ Kioti ck25 slow in medium range #2
Welcome to TBN. Sorry you're having a problem with your CK. What year was it manufactured? Did you do any recent services on it? I take it that you have an HST unit? What if any symptoms occurred before the current status?
What do you use it for most often? Are you using a MMM for lawns?
When does it 'go slow' in mid range; cold, hot, always?
You also have a Bobcat CT225?
How does that unit work for you? How many hours on it/year mfg?
/ Kioti ck25 slow in medium range #3
If it does it in all the ranges, check your forward/back pedal first. Unless Kioti changed the design, these pedals where known to bend. Mine did the same and after checking, I found that the pedal would hit the floor/foot rest before the actual drive linkage, under the foot rest, was through all its travel. I just bent mine back and all was fine. Some members have posted reinforceing this pedal by welding on a steel square bar. The ranges are all geared, so if it's slower in medium, it should be slower in the other ranges too.
