Kioti ck25 front drive shaft
   / Kioti ck25 front drive shaft #1
Leonard malone
Bronze Member
Kioti ck 25
I have a 2006 ck25 and something is gone in the front differential. I use it daily and have been all summer with front wheels disengaged. I have to fix this before the snow comes but without taking it apart I don't know what has to be replaced. If I take out the front shaft will I still be able to use it in 2 wd? Thanks, any input would be much appreciated, Len.
   / Kioti ck25 front drive shaft #2
On a tractor, the entire drive train for the front axle still spins all the time, even in 2WD. It's simply not connected to the rear axle.
So you may want to figure out exactly what's wrong with it before causing any more damage.
Thanks for the info.guess I better take it apart and see.
thanks for the info. Guess I better take it apart and see. I'll have to get a real mechanic to take a look.
2018 HINO 195 16FT BOX TRUCK WITH LIFT GATE (A53426)
2018 HINO 195 16FT...
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
UNUSED RAYTREE RPRB72-72" POWER RAKE BUCKET (A51248)
UNUSED RAYTREE...
