Kioti ck25 does not have any power.
   / Kioti ck25 does not have any power. #21
I believe the ck 25 was a bit under powered that's one of the reasons kioti replaced it with the ck 27 with 28 hp. Don't forget that ck 25 is a very heavy tractor. I believe quit a bit heavier than the comparable tractors in this size and generally has less hp. plus this one had loaded tires and bushog. I would venture to guess that if the other tractors tested had equal weight,traction,hp and were hydro results would be similar.
I have a CT 225 (almost a twin to CK 27)with r4s and hydro, there are times when I can get enough traction when using dif lock and weight on hitch to hit hydro relief or stall engine.
My Kubota L3240 has R4 loaded tires, a loader, and a backhoe. This brings the weight up to over 8,000 pounds. I'm guessing the kioti weighs about half that and only has 7 less hp.
   / Kioti ck25 does not have any power. #23
Kioti CK 25 weighs in about 3000 pounds just tractor add approximately 900 for loader loaded tires at 6 to 800 for the bushog u tell me maybe 800? Depending on brand.
Total weight= somewhere around 5400 pounds plus operator.
I think 800 for the tires is a bit much. The tires on my Kubota are considerably larger and only have 900 pounds of rim guard. The bush hog is a cheap one and 500 pounds would be pretty close. My Kubota weighs 3,153 just the tractor. The loader weighs 1163 w/o the bucket the bucket weighs about 300 the grapple is even heavier. The backhoe&subframe is about 2500 plus 130 for a bucket. The tires have 900 pounds of fluid in them. This brings the weight to 8,146. We will go with the 5,400 pound estimate for the kioti which I think is a bit much. We will consider the gross hp on the Kubota is 34 vs 25. This gives the Kubota 9 more hp to spin 2,700 extra pounds.
   / Kioti ck25 does not have any power. #25
To me that's asking a lot of 25 hp. And 7 hp is quite a bit when we're only talking 25 horse. Plus not trying to stir trouble but unless you have a cab or some other added weight I think the L3240 weighs in around 3400 # and depending on what backhoe add 900 to 1500. Loader and filled tires should be close to same on either tractor. That's only about 500-1000# difference and I think the L3240 has more like 34 hp so that's 9 hp difference.
My intention is not to offend I know the L is A awesome tractor. The CK line of tractors are very good but they needed two up the horsepower on the line and that's what they did. I think 30 or 35 hp. Is the lowest you can get currently in that frame size. All that said proper maintenance will be important especially on and underpowered machine.
I edited my last post. The Kubota has 9 more hp to spin 2,700 more pounds. Any tractor regardless of hp should be able to spin the wheels in low gear with a reasonable amount of ballets.
   / Kioti ck25 does not have any power. #27
Yes I agree it seems you see more hydrostatic tractors with this problem than gear. 9 hp is very substantial. And wow not sure what kind you have but that must be one heck of a Backhoe. I think a Woods BH 90 is in the neighborhood of around 1600 pounds and those are built pretty stout. Looks like the Kubota L got it right getting power to the wheels.
   / Kioti ck25 does not have any power. #28
A 3240GL is a dog. Ask Fred, time to add a Turbo!!!:D
I am assuming gl means glide shift. My grandpas old L2550 was a glid shift. I didn't mind the glide shift, but the shuttle shift is a POS. The old L2550 GST passed this test in 5th gear. My grandpa traded the L2550 for a L3800 HST last week. I will go test it out this week. Forget the turbo. A V12 Cat should do the trick.
   / Kioti ck25 does not have any power. #30
gl-grand Lseries.
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2006 Wells Cargo 8x16 Trailer (A55973)
2006 Wells Cargo...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
NEW Woods 6ft Finish Mower (A55315)
NEW Woods 6ft...
