Kioti CK20S Hydraulic issues
   / Kioti CK20S Hydraulic issues #11
well after lots of extra work I caused myself I have it fixed. when I found the pump all tore up I went and took the priority valve apart and when I put it back together I didn't tighten the pressure relief valve in. Not sure how it wasn't leaking as it was only just started in the threads. I tightened it back in and everything worked. I wish I would not have screwed that up the first time around it would have saved me a lot of work. But it is working now!
Thanks everyone!
Thx for update. If you ever figure out why pump failed let us know. I wonder if your dad real caused the problem or was just operating when failure occurred. I did not have backhoe on when my first pump ate itself and fuel cam broke, I was operating in heavy brush (jungle) w/PTO running bush hog, lots of vines and sticks I believe hydraulic selector got pushed/pulley back and deadheaded without me hearing due to engine & rear PTO noise. I believe subsequent failures may have been due to insufficient hydraulic flush and/or more deadheading, (maybe operator error, mine). either way I wish when rear output are installed a bypass pigtail hose was supplied and the hydraulic directional lever had a manual lock pin feature. Glad you are running hope it stays that way👍
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
