Kioti CK20s hard starting: possible causes
   / Kioti CK20s hard starting: possible causes #1
choirnot
Ontario
NH 3045
I recently purchased a used 2009 Kioti CK20s with a hard starting issue. As I began to use it more frequently, the issue became untenable as I would invariably burn out the starter motor. After much research (and trowing parts at it), I finally fixed it. Seeing as I relied on the vast amount of knowledge found on the Tractor by Net forum, I thought I should give back to the community by writing down the steps I followed to resolve my problem. I learned a great deal from the Tractor by Net forum denizens and this is my way to give back.
Disclaimer
I'm just a guy that bought a tractor with starting issues. I am not an expert and this post should not be construed as official, dealer sanctioned advice in any way, shape or form. Also, English is my second language so :p.
My tractor's general hard starting symptoms
When I first purchased the tractor, I had a great deal of trouble starting it. Regardless of temperature, time of day, moon phases, it would take a good 4 to 10 starting cycles before it would finally start up. The tractor would puff a fine white mist of diesel out the exhaust for one or two rotations and then continue turning over without any more smoke and without coughing to life. This would happen regardless of how many times I cycled through the glow plugs. And no matter how long I held the key to the starter position, it would never fire up or even cough. Sometimes, If I immediately turned the key straight to the start position (all the way to the right), the tractor would cough black smoke for a few revolutions and then revert back to simply turning over without ever firing; no further diesel mist out the exhaust either.
And when it did run, shutting it off was more of a suggestion. It could take anywhere from half a second to 3 seconds to shut off. This last symptom should have been the key one to investigate. But being new to diesel tractors (at least modern ones), I led myself on a wild goose chase.
The possible causes that I explored
1. Bad glow plug(s)
If one or more glow plugs are on their way out, your tractor will be hard starting. However, you should still have it attempt to start. You should get some black smoke coming out of the exhaust indicating that it is firing on one or more cylinder. If not, a fine mist of diesel should be coming out the exhaust.
To test the glow plugs, you should firstly ensure that you are getting power to them. Disconnect the first glow plug (starting from the front of the tractor) from the second by unscrewing the tips of the two plugs and remove the connecting wire. Don't be lazy and only unscrew the middle (second) glow plug tip and bend the tab back up. It will snap. Ask me how I know.
Using your multimeter's high current setting (10a), bridge the first glow plug to the second using the probes and turn the key to the glow setting (on). If you get approximately 7a, you are good. If you do not get any current, follow the same procedure between the second and third glow plugs to identify where continuity is lost. Make sure you do not reconnect the first glow plugs when attempting this step as it will blow the fuse in your multimeter (10a).
If you still do not get any current, the most likely culprit is the glow plug relay (or the glow plug timer?).
While you are in there, you can test the glow plugs to ensure that they are within spec. You can test them by using the lowest resistance setting on your multimeter. You should see less than 2 ohms of resistance and ideally it should be around 1. I had two glow plugs way out of spec. I therefore purchased three new glow plugs from my local Bobcat dealer as they were less than half the price of my Kioti dealer. The glow plugs are made by NGK for Bobcat and Kioti but I was unable to locate them outside of the dealer network.
Unfortunately for me, this procedure did not really help my hard starting issue.
References:
Bad glow plugs video
Testing glow plugs
NGK YE11 glow plugs specs
Part Numbers:
Glow Plug Relay - T5535-69951
Glow Plug Timer - T2305-60234
Glow Plugs - E5760-65511 or Bobcat #6694558
2. Gelled diesel
Because I was only getting a few puffs of diesel mist out the exhaust for one or two revolutions, I thought perhaps the tractor had been sitting for a while with summer blend diesel awaiting its new owner (me). I added diesel Power Service to the tank and topped off the tank with fresh winter diesel with more Power Service added. That did nothing to alleviate the symptoms. I then decided to replace the fuel filter because well, why not.
To replace the filter, shut off the fuel petcock on the filter bowl. Place a drain pan under the bowl to capture the cup or so of diesel that will spill out. Unscrew the large retaining washer thing. Pull out the old filter and replace with the new one.
Reinstallation is done in reverse with one exception. After turning the petcock back to the on position, make sure to refill the bowl by slightly unscrewing the the philips head screw next to the petcock. This will allow diesel to fill the bowl and air to escape. Once diesel starts to overflow through that little screw, tighten it back down. Using this method will prevent air from entering the fuel system.
Unfortunately this step did not help my hard starting issue.
References:
Discussion about fuel filter part number
Discussion on bleeding the fuel filter bowl
Part Numbers:
Fuel filter - Kioti 76KD-10331, Bobcat #6694422, NAPA NGF3389
3. Key Switch
As I read discussion threads on hard starting issues with the CK20 model, one of the most frequently mentioned item was the key switch assembly. The key switch tends to gelled up with ice, or just plain gets dirty. Some of the symptoms are the glow plug relay not clicking on and the fuel stop solenoid plunger assembly pokey bit not retracting (more on this one below).
In my case, the glow plugs were getting power however, I was only getting intermittent power to the fuel stop solenoid plunger assembly.
To remove the key switch assembly, take the kick panel off from under the dashboard. You can remove the rubber/plastic handles from the parking brake and cruise control levers simply by pulling on them. I also removed the top two screws and the lower bolts from the dashboard. This allowed more room to work under the dashboard by lifting it up a bit.
Once out, I disassembled the key switch assembly being careful not to loose the little spring in the middle. The assembly was surprisingly clean however the spring was very weak. I confirmed that contact wasn't always occurring with my multimeter set to resistance. I stretched out the spring knowing that this is only a temporary fix as it will compress back down with time. I packed the assembly full of dielectric grease and reinstalled.
After reinstalling the key switch assembly, power reached the fuel stop solenoid plunger thing 100% of the time. Unfortunately, this did not fix my hard starting issue. Nuts.
References:
Tractor by Net's very own ritcheyvs' web site with detailed instructions on taking apart the key switch and more
4. Fuel stop solenoid (plunger thing)
Based on my understanding of the discussion thread listed below, the fuel stop solenoid works by retracting a plunger thing allowing diesel to flow into the engine. When the key switch is set to off, the fuel plunger thing extends back out preventing diesel from flowing.
When looking at the engine from the right hand side (passenger side?), the fuel stop solenoid is located at the front just before the cooling fan. It looks like a small metal can.
I thought that mine may be experiencing difficulties because of the delay in shutting off the tractor. Maybe the plunger wasn't moving consistently? The first indication that something was amiss was the large amount of gunk covering the front of the solenoid metal can.
To remove the solenoid, I firstly disconnected the electrical connector by removing the metal clip (*you will curse the day Kioti engineers decided upon that type of connector when you try to reinstall that little bugger) and then pulling gently on the connector. I then removed the two bolts holding it on to the engine. I had just enough space for a 10mm wrench to work. Once removed, I tried to manually actuate the plunger by pushing it into the solenoid. Oil came squirting out from the plunger shaft seal. Worst yet, when I let the plunger go, I noticed that it took a few seconds for it to fully extend again.
While I'm not a mechanic by any stretch of the imagination, my theory is that positive crank pressure was pushing oil past the seal and pressurizing the solenoid's metal can. The pressure built up to the point where oil was slowly seeping through the other end of the can. This explained the gunk on the top portion (front of the tractor) of the metal can. I pumped the plunger a few dozen times wiping off any oil that came out. After this, the plunger freely extended back out without any resistance. I reinstalled the fuel stop solenoid and voila, the tractor started on the first try.
Over the next few days, the tractor never failed to start on the first try regardless of the temperature or the extent of time between starts. I also noticed that when I turned the key to the off position, the tractor would immediately shut off; no more 2 second delay. I realize that I will eventually have to repeat this procedure as the fuel stop solenoid will get pressurized with oil again. I think I will simply replace the solenoid next time.
References:
This was the discussion that clued me into what was really happening. The diagram is for the older CK20 model but the procedure is mostly the same.
Engine stop lever group
Part Numbers:
Fuel Stop Solenoid - E6820-60011
This is where my quest in fixing my hard start issue comes to an end. Hopefully some of this will be helpful to someone in the future.
Cheers
   / Kioti CK20s hard starting: possible causes #2
VERY WELL WRITTEN.. & thank you.
   / Kioti CK20s hard starting: possible causes #3
I'm having almost the exact same problem with my DK55C. I'm encouraged that this post may help me with this very annoying problem. Thanks!!
PWR
   / Kioti CK20s hard starting: possible causes #4
Hopefully, you get it fixed. Solenoids don’t last forever and are a reasonably simple thing to check and fix.
   / Kioti CK20s hard starting: possible causes #6
Excellent post choirnot! I've been having intermittent starting problems too. But I suspected it was a relay or solenoid because I could hear a "CLACK" of a solenoid on the occasions the tractor did start, and when there was no "CLACK", the tractor wouldn't start. Earlier tonight I was able to track down the CLACK sound to the fuel shut off solenoid. Mine's filthy too, so I'm betting it has suffered the same failure mode as yours.
A quick update.
The original fix to was to clean the solenoid by manually actuating the the plastic plunger to remove the diesel/oil trapped behind the rubber seal thereby reliving the pressure. Recently, my usage of the tractor has increased exponentially leading to having to clean the the solenoid on an almost weekly basis. I also noticed that the time between key off and the tractor actually shutting off increases proportionally to the number of start/stop cycles since the last cleaning.
I called up my local Kioti dealer and was quoted 145$ canukistan copecks for a replacement solenoid. Being frugal (read: cheap), I decided to try to "fix" the old part. Worse thing that can happen is that I break solenoid and need to buy a new one anyway.
I noticed that the solenoid has two parts numbers: E6820-60011 and E6850-60011, the former superseding the latter. This leads me to believe that Kioti is aware of the issue.
I proceeded to clean the solenoid once again and noticed that the pressure appears to build up only in the first part of the can right behind the plastic plunger. Pressure builds up in behind the seal thereby overpowering the solenoid's ability to pull in the plunger.
I took the smallest drill bit I had on hand (3/32" ), and drilled* a hole into the first part of the can right behind the rubber seal. The idea being that as the plastic plunger retracts back into the solenoid on startup, the diesel/oil liquid is pulled in past the seal. With that little hole drilled into the can, the liquid simply leaks back out of the can straight into the engine. Since modifying the solenoid a few days ago, I noticed that the tractor has not exhibited the tell tale symptom of progressively slower shut off time.
*Take care when drilling into the metal can as there appears to be a plastic inner portion. Only drill into the metal portion. You will know when to stop when to can actuate the plastic plunger and see liquid/air leaking out of your newly drilled hole.
I will update the thread in a few days after a few more start/stop cycles.
   / Kioti CK20s hard starting: possible causes #8
I pulled out the stop solenoid and did a quick bench test on it to check continuity. It seemed A-OK. Applying power on the bench snapped it back with a clack. The real problem (for me) wasn't the stop solenoid. It was the cheap Omron relay
It passed a continuity check, but wouldn't pass enough current to properly energize the solenoid pull coil.
I'll definately keep an eye out on those two parts going forward as well.
This is the part that is/was my issue:
Toro Mower (A50324)
Toro Mower (A50324)
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
6' 3pt Rotavator (A50121)
6' 3pt Rotavator...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
