Kioti CK 30 loader rollback droop under load
   / Kioti CK 30 loader rollback droop under load #1
DOCatRU
Wallingford, VT
Kioti CK 30 (2008, gear drive, 415 hours)
Hi folks:
I have a recurrent problem with my FEL on my CK30. Over the past I had two separate instances where the loader would droop down under load. The first time it was fixed with a leaky hydraulic line from the loader to the joystick control valve. The second time it was fixed by a leaking o ring in the quick attach fitting.
The loader has been fine all summer. I lift logs and pallets of firewood to store in the shed. No problems. I did not use the tractor for 3 weeks. Last week, when moving a pallet of firewood to the house this problem showed up.
I can rollback the firewood pallet while on the ground and lift it into the air; but almost immediately the rollback starts drooping and it will not stop. If I move the joystick to the left it will not hold the load, nor will it hold the load if I increase the throttle.
I have a video demonstrating the fault, but can't seem to upload it.
I cannot see any sign of a hydraulic fluid leak. Your advice is most welcome!!
DOC
   / Kioti CK 30 loader rollback droop under load #2
If I am understanding it correctly - we've seen this on new Kioti CS series loaders - we brought the roll cylinders to a local hydraulic shop and had them rebuilt - fixed the issue.
Cylinders are $360/ea from Kioti
   / Kioti CK 30 loader rollback droop under load #3
When my CK30 was doing that one of the cylinders had a seal gone on the piston. The seals were the same price as a new piston around $100 so I bought the piston and installed it right on the tractor in about 1/2 hr. To determine which cylinder I curled the bucket and let it bypass for a min. or so then felt the cylinders where the piston is in the curl location and the warmest one was the culprit. A heat gun would work as well.
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
Leeboy 8500 Paver (A47477)
Leeboy 8500 Paver...
M998 (A55852)
M998 (A55852)
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
