Kioti CK 30 loader rollback droop under load
   / Kioti CK 30 loader rollback droop under load #1
DOCatRU
Bronze Member
Wallingford, VT
Kioti CK 30 (2008, gear drive, 415 hours)
Hi folks:
I have a recurrent problem with my FEL on my CK30. Over the past I had two separate instances where the loader would droop down under load. The first time it was fixed with a leaky hydraulic line from the loader to the joystick control valve. The second time it was fixed by a leaking o ring in the quick attach fitting.
The loader has been fine all summer. I lift logs and pallets of firewood to store in the shed. No problems. I did not use the tractor for 3 weeks. Last week, when moving a pallet of firewood to the house this problem showed up.
I can rollback the firewood pallet while on the ground and lift it into the air; but almost immediately the rollback starts drooping and it will not stop. If I move the joystick to the left it will not hold the load, nor will it hold the load if I increase the throttle.
I have a video demonstrating the fault, but can't seem to upload it.
I cannot see any sign of a hydraulic fluid leak. Your advice is most welcome!!
DOC
   / Kioti CK 30 loader rollback droop under load #2
If I am understanding it correctly - we've seen this on new Kioti CS series loaders - we brought the roll cylinders to a local hydraulic shop and had them rebuilt - fixed the issue.
Cylinders are $360/ea from Kioti
   / Kioti CK 30 loader rollback droop under load #3
When my CK30 was doing that one of the cylinders had a seal gone on the piston. The seals were the same price as a new piston around $100 so I bought the piston and installed it right on the tractor in about 1/2 hr. To determine which cylinder I curled the bucket and let it bypass for a min. or so then felt the cylinders where the piston is in the curl location and the warmest one was the culprit. A heat gun would work as well.
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
Quick Attach EZ Axe Skid Steer Tree Shear (A52128)
Quick Attach EZ...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
