Kioti CK 30 HST runaway throttle and wouldnt shut off.
   / Kioti CK 30 HST runaway throttle and wouldnt shut off. #1
knibloe
Upstate, NY
kioti ck30
I have a Kioti CK 30 HST. Yesterday while mowing, the engine went crazy. I tried to shut throttle it down. I turned the key off. Finally, had to shut the fuel off. I have talked to both local dealers (1 hour either direction) and they say I have to tow it in and they will look at it in 2-3 weeks. I really need it now for some planting or I won't have a business come fall. Don't honestly remember how old it its. I bought it used in 2009. Has about 1100 hours on it. It was running on winter blend if that makes a difference.
Anythig I can check myself before I have it taken to a dealership?
Pulled the fuel shut off solenoid and put power to it. It does not appear to be working.
   / Kioti CK 30 HST runaway throttle and wouldnt shut off. #3
fuel shutoff will kill fuel to the engine
wont
cause the engine to go runaway crazy
   / Kioti CK 30 HST runaway throttle and wouldnt shut off. #4
all the throttle does is tell the pump to add more or less fuel.
if the engine is runaway its getting additional fuel from the pump.
there is a company on here that rebuilds pumps. you might call them to verify whats going on.
   / Kioti CK 30 HST runaway throttle and wouldnt shut off. #5
Maybe a stick or something got jammed into the cable/mechanism and pushed it to full throttle.
No stick. It was way tooamped up. Found a Kioti thread that outlines fuel pump problems with this brand and year. Sounds like the injector pump is stuck open.
Where do I find the name of the company that rebuilds the pumps?
   / Kioti CK 30 HST runaway throttle and wouldnt shut off. #7
   / Kioti CK 30 HST runaway throttle and wouldnt shut off. #8
Search for the " thepumpguysc"
Big thanks to the pump guy for the rebuild and fast turn around. I had hoped to get a local repair guy to help me put everything back together. He hasnt called back. I'm not a mechanic, but is there any reason I can't put this back together myself?
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2013 Dodge Avenger Sedan (A50324)
2013 Dodge Avenger...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
2015 Toyota Prius Hatchback Sedan (A50324)
2015 Toyota Prius...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
Westfield 80-51 Transport Auger (A50774)
Westfield 80-51...
