cxg
I have a 2009 kioti ck 27 that I can not start using the ignition switch . A couple of weeks ago I was cutting grass when I noticed that the tach. and the fuel gauge had stopped working. The tractor was running fine. I shut the tractor down and when I tried to start it again the tractor would not start the oil light and the temp. gauge would work and I would here a click from under the hood, and the starter would not turn. I called the dealer that I bought the tractor from and was told that it was probably the ignition switch or a bad fuse. The tractor will crank and runs fine if I start it by arching across the starter. I checked the fuses nothing wrong there. So I called the dealer again and was told that Kioti had trouble with their switches, so I bought a switch when this didn't work the dealer said it might be a relay. I've found 5 total 3 on the back wall and 2 by the radiator How would I go about testing a relay?
