Kioti CK 2510 inline radiator heater
   / Kioti CK 2510 inline radiator heater #1
sneaky001
Lodi ohio
Kioti CK2510 / Allis Chalmers B
I am new with this forum and was wondering what you guys thought about in line radiator hose heaters. I want to put a heater on the engine due to some very cold Ohio weather we sometimes have. I don't really want to put a freeze plug heater in because its a pain and I don't want to screw something up. Just some thoughts on a radiator hose heater and if they work good. The heater will be going on a 25hp Kioti CK2510. Thanks.
   / Kioti CK 2510 inline radiator heater #2
Welcome to TBN and the forum - sneaky. In all the years I've spent in cold climates I've always used a lower radiator hose heater. They are easy to instal, they work very well and if they leak or need replacement - its an easy job. Its one of the heaters I used the year we spent in Glennallen, Ak. Saw -20F quite often and occasionally quite colder. Also had a "hot pad" under the battery, a magnetic heater on the oil pan & a trickle charger on the battery. I can truthfully say that I didn't appreciate our winter in Glennallen to much. It was the only type heater I used on my vehicles the years we spent in Anchorage.
   / Kioti CK 2510 inline radiator heater #3
:welcome: Welcome to the forum!
:tractor: I'm going to move this thread over to our Kioti section.
Thanks for the info guys. I'm going with the in line hose heater. Seems everyone says nothing but good things about it.
   / Kioti CK 2510 inline radiator heater #6
Sneaky, Not sure what's standard but if there are optional rear hydraulic remotes, I'd have them installed now. For years, I never used mine because I only used the tractor for mowing. Then I got a box blade and found adding hydraulic top and tilt cylinders made the thing 10 times more usable. Then I got a grapple and had to use one set of remotes for it until I installed a diverter valve. The parts for an extra remote are only a few hundred dollars and installation is easy for a dealer with a hoist that can easily remove the back wheel.
Yes, I can put up to 2 remotes on the tractor. Thats funny, I was just thinking of doing that also.
   / Kioti CK 2510 inline radiator heater #8
Don't know how cold you folks get it your area but I had one installed when buying my 2006 DK 35 when new. It works but in the really cold, (-20c to -30c range), I add 2 magnetic heaters, one on each half of my engine sump. Also added a battery blanket heater. Maybe overkill but my Kioti starts quite quickly in our winters. I may add another heater to my hyd filter.
ZeroStart™ Super Heat Magnet | Canadian Tire
Temro 8W Battery Warmer | Canadian Tire
Bob
   / Kioti CK 2510 inline radiator heater #9
ZeroStart Super Heat Magnet | Canadian Tire
Bob
Here is a situation that users of engine heaters do not think of.
Most newer tractors have a glow plug controller which decides how long the GP's will heat based upon engine temp.
Because the GP controller is usually using engine block temp to decide how much GP time to allow, with a warm block it can not heat the GP's long enough in very cold conditions.
The GP's are on only briefly if at all, because the block is warm.
In spite of the warm block, the engine is inhaling -30 outside air and it does not light off like it should.
Often there is a trick known to dealer's mechanics who have to move tractors around the lot for snow removal. For Kubota's, by putting the shuttle in forward instead of neutral and turning the key to start, you effect an manual application of the GP's where you control how long to heat.
When I use this trick the engine fires before it even turns over.
The latest Kubota's, when the dealer has installed a block heater, have a change made in the programming of the GP controller. The controller senses outdoor air temp and the GP's stay on the proper length of time rather than block coolant temp logic which does not give enough GP time.
Owner's who think they are saving money installing their own block heater are unaware of the programming change to the GP controller which should be done to have the tractor starting its best.
Dave M7040
   / Kioti CK 2510 inline radiator heater #10
Yes, when I have my block heater plugged in I have to cycle the key several times to get the manifold heater to be on long enough to benefit starting.
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
John Deere XUV 835M (A56469)
John Deere XUV...
TURN PLOW (A57192)
TURN PLOW (A57192)
UNUSED PABREAK METAL BEAR SHOOTING TARGET (A57193)
UNUSED PABREAK...
