kioti ck 20s
/ kioti ck 20s #1
warmor
black rock canada
250 belarus
i lost my hydraulics no 3pt or loader or steering i was moving logs and engine started to smoke a little then i lost my hydrauics and engine stopped smoking tractor starts fine but no hydros does anyone have any ideas
/ kioti ck 20s #2
What have you checked so far? Any leaks? Fluid level ok? Fluid condition foamy or milky or metal shavings?
/ kioti ck 20s
all looks good local mechanic says maybe my hydraulics got hot seized the pump then broke shaft that turns pump any thoughts on that he said also i may have to take the engine out to fix it
/ kioti ck 20s #4
Before you venture into full out expense have dealer print out page on pump and driving gear. Takes a lot to burn up a hydro pump plugged filter could be an issue or water in the system. Check these out first before getting into tractor and pump. If it’s driven gear you then can see the in-depth repair.
/ kioti ck 20s #5
Find a new mechanic. Maybe should be a diagnosis.
I would start by checking all fluids and filters, then look for any type of hydraulic diverter valve or valve stuck, then the hydraulic suction screen.
Is this a HST machine?
/ kioti ck 20s #7
no standard transmission
Remove the Fuel Injection pump and inspect the fuel cam shaft. The Hydraulic Pump is driven off the fuel camshaft. Inspect the fuel camshaft for shearing between cylinder 2 & 3 lobes, or after cylinder 3 lobe. We have also seen the key between the fuel camshaft and the drive gear shear, but the engine will not run when the key shears.
A smoking engine with the loss of hydraulics a definite symptom of a sheared fuel camshaft.
Hope this helps...
/ kioti ck 20s #8
The engine was smoking IMHO you should
check for broken hoses as the fluid must have
sprayed on the exhaust
I would definitely check with a different mechanic
I have never heard of pulling an engine for a
hydraulic leak but then again I don't work on
tractors
willy
/ kioti ck 20s
Hope this helps.
/ kioti ck 20s
My engine still runs so it could b broken shaft maybe What would u think. Thanks for your reply
/ kioti ck 20s #11
Yes, we have seen the shaft fail and the engine still runs. The shaft can fail between lobes 2 & 3, or after lobe 3. The engine will run, but possible exhibit smoking at times. Checking the fuel camshaft is not difficult, and should be one of the first things you check for this situation.
Hope this helps...
/ kioti ck 20s
Hope this helps...
ihave a shop looking at my tractor 2008 ck 20 s now it seems like shaft is sheared to the hydraulic pump like u said would u know whata shaft is going to cost me thanks
/ kioti ck 20s #13
Parts breakdowns for your tractor with current pricing can be found using the "Buy Parts on Line" feature at our website www.michiganironandequipment.com. The Part Number for the fuel camshaft is E5760-16171. This should be verified with the tractor serial number.
Hope this helps
/ kioti ck 20s
Hope this helps
if i cant find one in canada do u ship to canada
/ kioti ck 20s
Hope this helps
/ kioti ck 20s #16
/ kioti ck 20s
Hope this helps...
u were right about fuel cam shaft sheared now i have another problem i shut tractor off and now it wont start i have fuel right up to injection pump but none at injectors i have power to my fuel solenoid but not sure if its working.would there b any signs of failing solenoid or failing injection pump . i checked all fuses and r good . any ideas on what to check next thanks
2018 International HX620 Quint Dump (A62613)
2018 International...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
Deutz-Fahr 6140 (A64126)
Deutz-Fahr 6140...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
