kioti backoe.. like?
/ kioti backoe.. like? #1
bullet20
any of you guys have the kioti backhoes? how do you like them and how strong are they? fixing to buy one soon! the kb2475
/ kioti backoe.. like? #2
I really wanted a thumb on mine, the local dealer showed me how they welded on a, to me, a cheap thumb on the Kioti backhoe. Got the dealer I bought my CK35 from to put on a 7ft Woods with a nice 7 position thumb. Knew I would use that thumb a lot. Been happy with the Woods. :)
/ kioti backoe.. like? #3
I have a CK20 (s) HST with a Kioti kb 2465 backhoe. The tractor has about 600 hours on it and I estimate about 60 % of that time is with backhoe attached and digging stumps. The backhoe has operated perfectly and has not even endured a leak. Kioti has an excellent backhoe as far as I am concerned.
rimshot
/ kioti backoe.. like? #4
I have a CK30 with the Kioti BH. It's great, no complaints. It has more than enough power for the size of the tractor. In fact, it seems to almost be suitable for a bigger tractor. My only complaint would be that there is no cup holder on the operator platform!
/ kioti backoe.. like? #5
I have a CK30hst with the Kioti 2375 bh. One minor fix to one of the valves under warranty and no more problems. It works well and has a good bit of power, well reasonable for it's size. I can mount or unmount it under ten minutes. Kioti's current version, in the same size, is the 2475. It has a curved boom and the valve system is a newer and I heard a better design. The Woods and Rhino bh are also good products. Maybe something else to look at for comparisons. From what others have mentioned, the Woods subframe stays on the tractor, Kioti's comes off with the bh, and I have never seen the Rhino mounting. The Woods BH80x, 8 footer, would fit a CK25 to 35. They have a valve which lets you adjust the flow to the swing and a thumb option. Overall, I'm happy with my Kioti bh.
/ kioti backoe.. like? #6
The thumb option is also available for a Kioti backhoe. Check out the selection available from Michigan Iron. He engineers and fabricates these and many other handy gadgets himself. I have three things he designed and they are all excellent. Here's a couple of thumb options for a Kioti backhoe from Michigan Iron and he ships anywhere.
Michigan Iron & Equipment: Kioti Dealer
rimshot
/ kioti backoe.. like? #7
I have a 2465 on my ck20 gear tractor, the backhoe has ALOT of power for it's size. It has no problem lifting the frontend in the air if you are not careful.
I have not tried any other backhoe so I can't comment on them, but I am well satisfied with the one I have.
/ kioti backoe.. like? #8
I have the KB2365 on my CK20HST, couldn't be happier with it! :thumbsup:
I have to strap my tractor to a tree or my pickup truck when digging large stumps so that I don't pull the tractor right into the hole when digging. :D
In case your wondering, that stump did NOT win! :cool:
Click thumbnails for larger images.
thanks guys alot! and love those pics i cant wait to get it , its there now i just have to find a couple hours to go over to get it
/ kioti backoe.. like? #10
Be sure to add your location to your avatar,
Good luck with the machine,
Joel
/ kioti backoe.. like? #11
Kioti backhoes are generally excellent. I've had both Kioti and Woods. Basically the same quality. There were some issues with control valves in the 23xx series a few years back but the 24xx series seems very reliable from what I've seen on TBN and by my inspection in a dealer's lot they are essentially the same as the Woods.
Metal Trim Break for Siding (A65579)
Metal Trim Break...
2022 EZ-GO ELITE...
213135 (A64276)
213135 (A64276)
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
Brent 320 Grain Cart (A65640)
Brent 320 Grain...
