Oil & Fuel Kioti 84" Finish Mower
/ Kioti 84" Finish Mower #2
I think all of these use SAE 80W90 gear oil. This mower is actually made by Sicma of Italy. Sicma makes a good quality mower that is sold under many brands: First Choice, Kleen Kut, Kioti, Phoeniz, Farmmax, Deere, and probably others.
/ Kioti 84" Finish Mower #3
I have a KK finish mower and it takes SAE 80-90 gear oil. thats a safe oil to put in. Its got about 4000 acres on it now with no gearbox troubles .. . John
/ Kioti 84" Finish Mower #4
Also, if you store your machine in the weather, cover the gear case vent to keep rain out.
I noticed the characteristic "white" (water in oil) in my rotary cutter grease when I changed it last fall because my cutter sat out in the weather. I'm sure a little water would eventually cook off with use but maybe not before starting corrosion.
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
2006 Freightliner Auger Truck (A63689)
2006 Freightliner...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
CONEX BOX (A65643)
CONEX BOX (A65643)
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
