Kioti 4510se
/ Kioti 4510se #1
ernieatv
Bronze Member
ontario,canada
Kioti DS4510 HS, 2009
I'm having problem with my 2015 kioti 4510se re: reverse. Everytime I put it on reverse it's start rolling down the hill and I have to put the brakes to stop it. The grinding of the gears starts making crazy sound, does anyone have the same problem? Only on reverse
/ Kioti 4510se #2
Sounds like you are not getting it fully engaged in reverse.
/ Kioti 4510se
It's a shuttle, what can I do to fully engage it ? If I was to adjust the link, would that work? On the reverse is the problem
/ Kioti 4510se #4
THe linkage is where i would start. On my older shuttle it sometimes fells like it engaged but it didnt. I have to go back to neutral then back to reverse or it will grind
/ Kioti 4510se #5
I've had two Kioti tractors with shuttle geared tranny. They both were low hours unabused tractors and was common that they ground ma tad in shifting either direction-F or R. Try a double clutch depression and see if that makes it smoother.
FWIW, my DK35SE is now dead as it wont move in gear under power. It stopped moving completely while in reverse. Maybe that's the secret I'm hoping to learn soon?
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
PALLET OF MISC ITEMS (A67714)
PALLET OF MISC...
2022 PETERBILT 389 (A67714)
2022 PETERBILT 389...
Jeep Metal Tailgate Metal Decorative Sign (A66738)
Jeep Metal...
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
Asphalt Roller Tire (A68134)
Asphalt Roller...
