Kioti 3 PT hitch won't raise
   / Kioti 3 PT hitch won't raise #1
Bmckayl
Elgin, NB
Kioti CK27
My 3-pt hitch on my Kioti CK 27 won't raise..I have a tiller attached and haven't lowered or raised it since fall..tried procedure in manual but still won't work
   / Kioti 3 PT hitch won't raise #2
Do you have a loader? Do you have 1 or more rear remotes? If you have a loader, does it work? If you have remotes, are they all in Neutral positon? I assume the 3pt is down now? I can't remember if CK27 has draft control or not? If it has draft control, It should be all the way forward. What is the position of the MLS valve. the round knob below the seat.
Need more info.
   / Kioti 3 PT hitch won't raise #3
How long since hyd filter was changed????????????
   / Kioti 3 PT hitch won't raise #4
What K0USA said. I must have accidentally bumped one of my remote levers and guess what... no lift at the three point. The loader did work though.
   / Kioti 3 PT hitch won't raise #5
I have a Kioti CK20S that the three point hitch won't operate. I have changed the fluid and filter. I've turned the MLS valve all the way up. The fluid is full. I've also put weight on the arms and as one person told me, to slam them down. Nothing has worked so far. It doesn't have remote controls. Any advice would be appreciated
   / Kioti 3 PT hitch won't raise #6
if the MLS valve IS NOT the valve under your legs, adjust that one.
Mine moved one time and make the 3pt seem locked up. Just adjusting the know fixed it.
   / Kioti 3 PT hitch won't raise #7
The one between my legs is the one I adjusted. I went both directions with it, and still no movement on the three point.
   / Kioti 3 PT hitch won't raise #8
You still haven't said if you have a loader or rear remotes. If not try putting a very low air pressure in the fill hole with tractor running.
   / Kioti 3 PT hitch won't raise #9
Leejohn, don't think we're going to get an answer from the OP. His first and last post was in 2014! :)
   / Kioti 3 PT hitch won't raise #10
It does have a front end loader, and no rear remotes.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2012 BMW 328i Sedan (A50324)
2012 BMW 328i...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
