3-Point Hitch Kioti 3-pt hitch won't raise
   / Kioti 3-pt hitch won't raise #11
So is there a way to get around this? I've got a 2021 CK3510Cab and I'm wondering if you can use the "backhoe" valve as a pass-through without affecting the 3-pt? I am trying to hookup an additional summit rear remote to my already 2 existing rear remotes from the factory. I connected the summit block to the "backhoe" spool turned it on in the tractor, and lo-and-behold it worked! However I can't raise the 3pt at the same time. I'm assuming I would either have to install a t-fitting somewhere upstream and plumb that directly to the summit block, or if there is a way to run the "backhoe" and 3-pt at the same time, I'm game.
I've also got a 3rd function on the loader. Any and all help is very much appreciated, thank you!
404 (A52706)
404 (A52706)
20" Sea Container (A47384)
20" Sea Container...
2016 Ford Transit 250 Cargo Van (A53422)
2016 Ford Transit...
Engel 20' Boat (A50121)
Engel 20' Boat...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
