Loader Kioti 2410. Just did 50 hour service
   / Kioti 2410. Just did 50 hour service #1
bcss04
Kioti cs2410
I just did my 50 hour service on my kioti 2410. I'm having some trouble with my power steering and loader joystick. The power steering is stiff, although I worked it a bit and it loosened up a little. And the front end loader joystick is very sloppy. I was wondering if there could be some air in the system? Fluid level is good. Is there somewhere to bleed the air out? Any suggestions would be appreciated.
   / Kioti 2410. Just did 50 hour service #2
Very possible some air is in the system from the service. Working the steering and joy stick should clear the air.
   / Kioti 2410. Just did 50 hour service #3
Did you change the Hydraulic Fluid or just the filters? If you changed the fluid, what did you use?
I tried to just do filters but I lost most of the fluid in the process. I used traveller universal trans/hydraulic
   / Kioti 2410. Just did 50 hour service #5
Is there that much fluid that comes out when you take the filters off?
Yes. Hydraulic filter is horizontal at the bottom of tank.
   / Kioti 2410. Just did 50 hour service #7
My CK 30 joystick was sloppy after a few months due to the little balls weARING AT THE BASE OF THE JOYSTICK. THEY REPLACED THEM UNDER WARRANTY AND THEY HAD BEEN GOOD FOR A FEW YEARS NOW UNTIL I TRIED JUMPING OFF MY TRACTOR AND THE JOYSTICK WENT UP MY SHORTS AND I BROKE SOMETHING. THE JOYSTICK FLOPS EVERYWHERE NOW BUT STILL WORKS OK, however I am going to have to fit a new Kit in it I can see.
(NO. I am not going to retype all this because I hit Caps lock)
   / Kioti 2410. Just did 50 hour service #8
lol, just go buy you a new tractor Alien :)
   / Kioti 2410. Just did 50 hour service #9
I wish. But I love my little Panther and it is getting a new Flail mower TODAY! yay.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
40' CONTAINER (A51244)
1985 Chevy C8500 Altec D800 Digger Derrick Truck (A50323)
1985 Chevy C8500...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
