Kioti 2365 backhoe pulls tractor
/ Kioti 2365 backhoe pulls tractor #1
darkviper
I just recently got a backhoe for my ck20. But it pulls the machine to easy. The stabilizer pads are smooth so i am thinking of bolting some angle iron on it to help. Just wondering if any of you have any ideas that work better /forums/images/graemlins/grin.gif
/ Kioti 2365 backhoe pulls tractor #2
Keep all four tires on the ground and lock the Brake as far down as it will go. That works for me.
/ Kioti 2365 backhoe pulls tractor #4
Yep, you're on the right track. My stabilizers are a piece of channel, about 2" deep. I can't imagine my machine holding still with smooth pads. Keeping the FEL bucket curled down with the cutting edge stuck in the dirt helps a lot but not sure if it's recommended.
/ Kioti 2365 backhoe pulls tractor #5
Do the smooth pads flip over to a high traction side?
No i wish they did though /forums/images/graemlins/crazy.gif. You would think as light as that tractor is that that would be standard equipment.
/ Kioti 2365 backhoe pulls tractor #7
If an one has a picture of these pads please post it. I would like to see how they are made.
/ Kioti 2365 backhoe pulls tractor #8
Another trick is to dig the loader toothbar directly down to anchor the machine while using the BH.
ok but i was always under the understanding that you never extend the bucket cylinders when exerting any backward force as it could buckle the cylinders. Is this incorrect?
/ Kioti 2365 backhoe pulls tractor #10
"ok but i was always under the understanding that you never extend the bucket cylinders when exerting any backward force as it could buckle the cylinders. Is this incorrect?"
That would make it pretty tough to backdrag.
PORTA POTTY (A68842)
2006 LeeBoy L8510R Low Deck Asphalt Crawler Paver (A66734)
2006 LeeBoy L8510R...
2015 John Deere 319E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
