Kioti 2007 Hydraulic problem CK20S PLEASE HELP
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #1
wattsinwest
somers,ny
Kioti ck20s
Hi gentlemen,
Need some major help here, average home owner. just bought used unit and working it hard.
All started when my backhoe encountered a broken hose and I temp-repaired it.
The unit started to get weak pressure and move slow, I disconnected the backhoe and tried the front loader. It was slow acting also.
I then tried to operate the steering, that also started to fail.
I drained the fluids and changed filters, thinking maybe that is the issue?
Not to mention that I changed the oil filter ,fuel filter, air filter, lubed the unit. Thinking that I will be golden.
So the big test on Friday the 13th?? I started the unit and let it warm up, tried my front loader ( Nothing ) 3 point hitch ( Nothing ) steering ( Nothing )
I'm concerned I destroyed the Hydraulic pump, If so. Is it worth fixing. Please help some one..
Best regards,
Tractorless..
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #2
Proper fluid level?
Will it move fwd/rev?
not familiar with that age of unit but....have you crawled underneath and inspected for any loose plugs?
There maybe something electrical that is holding it out.
Does it have a Loader lock out? is it in the lock/unlock position?
Someone with hyd. experience should chime in soon....
on edit did you drain the hyd. fluid? was it discolored, grayish, brownish any metal shavings pouring out from drain. How about metal shaving draining from any of the filters when removed for service?
Those are about the most common things that come to mind so when other jump in you are ready.
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #3
Did you lose all the hydraulic oil and keep running the tractor ?...
No I did not, there was fluid in there. but when I release the clutch it makes a grinding loud noise.
When i changed the fluid there where metal filings on the magnet plug.
Level ok
yes it moves forward and reverse-no stering.
yes looked under
electrical?
loader lock out? where is that?
yes drained fluid-looked grayish-metal shavings very small.
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #6
Hi gentlemen,
Best regards,
Tractorless..
What do you mean you temp repaired it? What did you do? When you disconnected the BH did you shut off the remote or did you leave it engaged? There should be a valve with an A-N-B position... once the BH is removed that vave needs to be put in the N position. At least there is on my Kioti DK35
I installed a metal sleeve with hose clamps, I don't remember disengaging any controllers.
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #8
You said you disconnected the BH... I don't have a CK20, but with my BH I need to place the rear remote valve in the N position or I will damage the hydraulic pump when I disconnect it.
IDK , but That's why I'm here Need help to repair or get it fixed.
thank you for your kind help.
   / Kioti 2007 Hydraulic problem CK20S PLEASE HELP #10
Using a metal sleeve and hose clamps shows you have no appreciation of how dangerous a hydraulic leak can be.
Injecting high pressure fluid through your skin and into your body is incredibly dangerous and, if you do it, you need to get to a hospital
Before you injure yourself, get some knowledgeable help.
Further the risk to causing serious damage to a component or pump is very real and happens in a fraction of a second. There is no: "lets just try it and see what happens."
This is a photo of the result of a hydraulic mistake, Part no longer available.
Dave M7040
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
LOT LOCATIONS (A52576)
2021 John Deere 410L Backhoe (A53342)
2021 John Deere...
