Kioteer or John Kioti?
/ Kioteer or John Kioti? #1
philshel
Oakhurst, CA
Kioti LK3054
Thought I’d show my latest project. Picked up the hoe at auction for $2200 with a sub-frame. It is in good shape, all the pins are tight, just needs a new seat and so far one slightly leaky valve. The adaptation was fairly easy, I added a couple of cross-members to the sub-frame and bolt it to the tractor at the drawbar location. Added a couple of brackets to the loaders sub-frame for the front pivot point on the hoe’s sub-frame and that was pretty much it. I did build a crossbar type item that fits through a section of the hoe. I use it to lift the hoe into position with the lower 3-point arms, but it does help carry some of the weight if I leave it in the up position. The hoe has a simple hydraulic set up with just a in and a out which I will run off of my rear remotes. I plan to update the tractors main hydraulic pump to one of the newer higher volume models. However, I could not resist playing a little with it as is. It seemed to work well with the lower volume pump, could use a little more ‘umph’ but overall not bad.
/ Kioteer or John Kioti? #2
Coming from a guy that purchased his hoe new take it from me, you saved a chunk of money doing it your way.
I'm thinking for you to get any luckier you would most likely have to win the lottery. You did real good! /forums/images/graemlins/grin.gif
/ Kioteer or John Kioti? #3
Man, I've tried to tell you, it's KiotiJohn!
Seriously, you hit the mutha load and did a great job adapting that hoe. Now if you buy some Allis Chalmers Orange, I think you can make it look right. John
John, I knew you would have something to say about my name choices! /forums/images/graemlins/grin.gif
Mike, yes I have been very lucky with this tractor. I found the tractor in like new condition with only 90 hours on it. I got the tractor, loader, a box blade, and a regular grader blade all for 9K and now a decent price on the hoe. I could not be happier.
/ Kioteer or John Kioti? #5
You did do well. That's a very good tractor isn't it? The newer model is even better, but costs a BIT more. John
/ Kioteer or John Kioti? #6
You sure are buying it right. The deals you're finding are far and few between. Good luck with your BH. Gerard
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
2017 Hyundai 53' Dry Van (A62613)
2017 Hyundai 53'...
