Kioritz SRM 302 brushcutter oil mix?
   / Kioritz SRM 302 brushcutter oil mix? #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
This brushcutter was my father-in-law's and I have no manuals for it. I'd like to know what the fuel/oil ratio is. I couldn't find any info about it on the Echo site either. Does anyone know where I could get a manual? Thanks.
   / Kioritz SRM 302 brushcutter oil mix? #2
Have you considered one of the synthetic oils that cover a range of mixtures? Amsoil Saber 100:1 comes to mind.
   / Kioritz SRM 302 brushcutter oil mix? #3
or you could just run Echo oil mixed somewhere around 40:1. It's supposed to be mixed at 50:1 and should lubricate fine there, but if you just mix it a little heavier on oil I believe you'll be fine. The Echo oil is semi-syn and vastly superior to your typical 2 stroke oil on the market when that trimmer was new.
FWIW I run all of my 2 stroke equipment (Echo, Shindaiwa, Redmax, Dolmar) on Shindaiwa oil mixed at ~40:1 with premium gas.
   / Kioritz SRM 302 brushcutter oil mix? #5
I think That I may have the same.
On the housing it says Kioritz SMR 320A a 2 cycle oil gas mix a real pain in the *** but, I have to admit it still runs.Lucky, I guess.
which I believe it to be an ECHO
I was told that my model was 30-years old
Guess that's why I have to put cutting string on the head manually by cutting 2 equal lengths and feeding through head clip holders on the head.
I see you found a manual online. Is it very helpful?.
http://www.echo-usa.com/documentation.asp?Model=SRM-302ADX&lang=E
Operator Manuals, Safety Manuals, Parts Catalogs, Safety Videos - ECHO USA
What is exactly broken on yours ? These so called experts say the some the parts especial cables and there connections are no longer available .
not sure.
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2014 Ford Escape (A50324)
2014 Ford Escape...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55218)
Neckover GL24-2-7K...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
