Kioritz SRM 302 brushcutter oil mix?
   / Kioritz SRM 302 brushcutter oil mix? #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
This brushcutter was my father-in-law's and I have no manuals for it. I'd like to know what the fuel/oil ratio is. I couldn't find any info about it on the Echo site either. Does anyone know where I could get a manual? Thanks.
   / Kioritz SRM 302 brushcutter oil mix? #2
Have you considered one of the synthetic oils that cover a range of mixtures? Amsoil Saber 100:1 comes to mind.
   / Kioritz SRM 302 brushcutter oil mix? #3
or you could just run Echo oil mixed somewhere around 40:1. It's supposed to be mixed at 50:1 and should lubricate fine there, but if you just mix it a little heavier on oil I believe you'll be fine. The Echo oil is semi-syn and vastly superior to your typical 2 stroke oil on the market when that trimmer was new.
FWIW I run all of my 2 stroke equipment (Echo, Shindaiwa, Redmax, Dolmar) on Shindaiwa oil mixed at ~40:1 with premium gas.
   / Kioritz SRM 302 brushcutter oil mix? #5
I think That I may have the same.
On the housing it says Kioritz SMR 320A a 2 cycle oil gas mix a real pain in the *** but, I have to admit it still runs.Lucky, I guess.
which I believe it to be an ECHO
I was told that my model was 30-years old
Guess that's why I have to put cutting string on the head manually by cutting 2 equal lengths and feeding through head clip holders on the head.
I see you found a manual online. Is it very helpful?.
http://www.echo-usa.com/documentation.asp?Model=SRM-302ADX&lang=E
Operator Manuals, Safety Manuals, Parts Catalogs, Safety Videos - ECHO USA
What is exactly broken on yours ? These so called experts say the some the parts especial cables and there connections are no longer available .
not sure.
1838 (A51248)
1838 (A51248)
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
