KingKutter rotary mower swivelling yoke retrofit
   / KingKutter rotary mower swivelling yoke retrofit #1
Kent
Hartland VT
Power Trac PT-425 (2011)
I have an older model and happened to notice the picture of their new model now has a swivelling yoke (attaches to the toplink)...so I wrote to King Kutter and they wrote right back with a part number and price:
"Yes, we offer the swivel kit for those kutters which did not originally have this. The part number is 501027--36.75 plus shipping. To order this please call our parts dept. @1-800-228-2308"
My rear finish mower has a swivelling yoke, and it tends to follow the contour of the ground better than my bush hog, so I am hoping that a swivelling yoke will reduce the amount of gouging done by the KingKutter (6' model). (the new JD and Woods bush hogs use this setup).
   / KingKutter rotary mower swivelling yoke retrofit #2
<font color="blue"> a swivelling yoke...</font>
Gulp...! That's a pretty steep price for a piece of "U" shaped steel... /forums/images/graemlins/blush.gif
I bought a similar piece from a Bush Hog dealer (special order) and it cost me ~ $9... maybe ~~ 3 years ago... /forums/images/graemlins/smile.gif
If worse comes to worst... retrofit two pieces of flat stock steel (& spacer) with 4 holes drilled... and it will serve the same purpose... (take measurements off an existing KK piece)
   / KingKutter rotary mower swivelling yoke retrofit #3
I agree with John, just use 2 pieces of flat stock.
The U shaft swivel King Kutter has is to wide and will not let the pin swivel through between the arms so I ended up cutting it into flat stock anyway.
   / KingKutter rotary mower swivelling yoke retrofit #4
I bought the 5' model KK Rotary, and have had the same problem. The U bracket is too wide and hits the uprights from the lower 3 pt hitch pins. /forums/images/graemlins/mad.gif I had to hammer the U part so that the legs of the U were close together so it would make it past the uprights. /forums/images/graemlins/crazy.gif Save your money and do as suggested and just make one.....
   / KingKutter rotary mower swivelling yoke retrofit #5
I have heard of some guys solving the problem quite sucessfully by adapting a length of chain as a toplink. The only drawback I can see to that is if you ever need to use the cutter as a wheelie bar.
   / KingKutter rotary mower swivelling yoke retrofit #6
On my 5' model, the slip yoke or whatever it is.. works good.. has just enough play in it to keep the mower from hanging on high and low spots...
Though i havn't experienced the clearance problem the others have with my NH 1920.. so I didn't have to modify it any.
Soundguy
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
2022 Polaris Ranger 4x4 Utility Cart (A55851)
2022 Polaris...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
Mobile toilet (A53424)
2020 Club Car Onward HP Li ION Electric Cart. (A53424)
2020 Club Car...
